What type of gas yall use
Double post.
  • Replies 49
My truck is equipped just about the same and don't get anywhere near that mileage for an average. I have noticed that my truck does get it's best fuel economy right there around 55 mph too though. I just don't spend much time at that speed.
I have a GMC 5.3 Z71 4x4 with 3.42 gears. I get 21.5-22 MPG overall per tank average all day, every day on 87 octane. UNTIL winter, then it goes down to about 19-21 on winter blend gas, and last years winter. Last winter was the coldest, longest, snowiest winter we have had in 30-40 years, so I hope to improve at least 1 MPG overall in a normal winter on the winter blend gas.
I live 2.5 miles from the nearest pavement, and most of my driving consists of back and forth to work 55 miles round trip. Drive through 2 small towns on the way, and 55 MPH on the highway with a traffic light at the half way point on the rural 2 lane highway between the two towns, and 5 stop signs each way. I easily get 24+ MPG on the 19 mile stretch between the two towns, with the traffic light at the mid-way point.
I just got back from a 3,800 mile trip out West to and through the Rockies. When it was all said and done, I ended up with 21.9 MPG overall.
THAT is awesome!
I've noticed the difference in cold weather too.
Couldn't get any good concrete numbers as the truck was new in March and it was the end of winter here.
THAT is awesome!
It's because cold air is more dense. So you get more air in the same volume of space into the engine. Of course more air means more gas needed for a proper air/fuel mixture which then means lower gas mileage. The more air and fuel is also the reason why in cold weather it feels like the car or truck has more throttle response.
I got mine back in April so like you I haven't had chance to drive it in the winter yet. This is also the 1st truck I've had (only owned Chevy trucks) that has remote start so that will make it much easier to let it warm up and all lol.
Just got my truck and i'm getting about 18-19mpg highway mileage running 87 octane from kroger.... little worse than i expected... Its stock height, 5.3, 3.42 gears 22inch gm wheels, crew cab 4x4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
