Battery Gauge
don1965
Took the new truck on its first road trip yesterday. Everything went fine except, I noticed that the battery gauge was at the low end of the normal area. All I had on was the a/c, in auto mode, and the radio. Is this normal? I'm used to seeing the gauge at 14 volts all the time. On the return trip, at night, the gauge read 14 volts as normal.
Something I'm missing here??
Yes it is normal. The Alternator unloads to save the engine from straining and helps to burn less fuel. My 2006 did the same thing. It just means that the battery is fully charged and does not need to work the alternator too hard.
Yotaman
Thanks!
Kind of what I figured, but just wanted to make sure. I never had a truck, or car, that has done that, kind of freaked me out!
For more information, Operators Manual helps. From page 5-15...
When the engine is running, this
gauge shows the condition of the
charging system. The gauge can
transition from a higher to lower or a
lower to higher reading. This is
normal. If the vehicle is operating
outside the normal operating range,
the charging system light comes on.
The voltmeter gauge may also read
lower when in fuel economy mode.
This is normal.
Readings outside the normal
operating range can also occur
when a large number of electrical
accessories are operating in the
vehicle and the engine is left idling
for an extended period. This
condition is normal since the
charging system is not able to
provide full power at engine idle. As
engine speeds are increased, this
condition should correct itself as
higher engine speeds allow the
charging system to create maximum
power.
The vehicle can only be driven for a
short time with the readings outside
the normal operating range. If the
vehicle must be driven, turn off all
accessories, such as the radio and
air conditioner.
Yotaman
I notice when my hid low beams is on and I'm on the road driving, the gauge would be at 14, but as soon as I turn off the headlights, the gauge would drop to 12 volts. So is this normal also?
And also, pretty much when I don't have the headlights on, the volts would be at 12, only when the lights go on, the volts go back up to 14. Thanks.
Yes Normal, when the lights are on the battery is being drawn on harder thus the alternator has to run to keep the battery charging up. You are all good.
Yotaman
Noticed this today while driving in the highway... Makes a lot of sense, great info to know.
Most times I see the gauge around 14v and today was around 11.5-12v (estimate)
Thanks guys for the info. I to was seeing the gauge drop to low normal range and was a little stumped.
Tapatalk via Moto X
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
