Post Pump Rub Problem-- Uh Oh
Noticed the small drops of oil on garage floor. Traced it to a rub hole in T case. ordered and installed the adapt-a-case retro part to address the issue, but now when go into drive and apply gas, very distinct and noticeable 'clunk' from drivetrain. At speed cannot detect anything odd--no vibration, etc. Come to a stop and ease up on brake and the same clunk happens, as if its unloading.
any ideas from the group?
2001 2500HD Ali with 8.1
thanks
this started immediately after the t-case rebuild. Literally first drive. when installed the rear D/S it all looked good. Perhaps the splines are binding? I read a TSB on the topic that initially recommended a GM grease, then that was revoked because the grease would migrate into the T case and cause problems. I also see replacement yokes, etc., but how/why would it only manifest as a problem when D/S was dropped? Worked flawless before.
You could remove the shaft and make sure the splines are getting fluid on them. If that doesn't work I don't know what to try.
Grease the slip yolk it's not gonna hurt anything, in fact when you change pinion seals their is a bead of grease under the lip of the seal...
D/S gets pulled this w/e. Read a cool fix is to drill and tap just fwd of the yoke flange a small grease fitting to every once in a while give it a shot of grease. Its just odd i pulled it apart, did the MA rub fix and reassembled. So why now its clunking seems more than coincidental...
Many slip yoke have a grease fitting. Makes maint. a breeze, it's a shame the bean counters cut this one out.
DEWFPO
