Bad hub?
Wraenking
So I'm just going by the original post, you said there was play in one of the hub bearings? If yes, then replace regardless if the noise is there or not. Just be sure it's play in the bearing and not something else going on. I just went through a hub bearing myself, it was noisy with no play for a few hundred miles and then on the way to the garage I used to replace the hub it gave way and I could actually feel the truck being held back on every revolution of the tire on that side. On my last hub bearing it went from humming one day to sounding like my diff blew apart the next. Trust the Rob (govtech4), get it checked out before you have bigger problems.
