Interesting Fan/Denali Temp Gauge Observations
Jon A
I did some experimenting.... I removed the fuses for the engine fans to make the thing warm up a bit.
First observation, the temp Gauge. It should be no surprise GM makes a "dead spot" in the temp gauge at normal operating temp so drivers don't fret if it gets a bit warm, etc as they've been doing that for a long time. With the digital gauge of the Denali, they can obviously control this very precisely. If you've noticed it never moves off the 210 degree mark, no you're not imagining things and no, the engine really isn't running that steady a temp.
I didn't pay quite as close attention on the way up, but somewhere around 190 degrees (ECT on a scanner) the temp gauge jumps to 210 and stays there. It won't move off the 210 mark until the actual temp is about 225 degrees. So, with the Denali you have a "dead spot" of about 35 degrees where the dash gauge won't move off the 210 mark. Not even a millimeter. While I would certainly prefer an accurate gauge, I don't think there's anything we can do about it. If you want to know the actual temp, use a scanner (Torque on your phone works fine for that). The reason I did this was simply to find out exactly how hot it had to get to make that virtual needle move--answer is 225. Non-Denalis won't be exactly the same, of course, but I'd expect they have a pretty large "dead spot" built in as well; somebody else will have to figure out the translation for those gauges.
The second thing I learned during this test I really didn't know about--once you exceed a certain temp (225 or 228, I'm not sure which is the controlling table), your fans will stay on at 51% speed after you shut off the engine. Over 234 and they'll stay on at 76% speed. For up to 5 minutes.
I had seen the settings in HP Tuners, but this computer has all sorts of settings (supercharger, turbo related, electric water pump, electric thermostat, etc) that aren't used so I didn't know they were "activated" or whatever. Apparently, they are.
This is good news in my opinion. When I put an aftermarket electric fan in a vehicle I usually wire an override switch that can turn on the fans with the engine off for exactly this reason. This is great if you do find yourself overheating--you can pull over and shut the engine off and the fans will cool the water in the radiator without your engine producing heat. Shut the engine down and let the fans run for a while, start it up and it's instantly cooled off.
You can put the settings wherever you want as well with HP Tuners or the like. Another useful purpose is for those who drag race--they can set the temps really low so the fans will always stay on for a while after a run, helping it cool down much faster.
Anyway, I figured this was pretty useful info as Summer approaches.
A over-ride switch will not work on these vehicles unless you use a pulse width modulated (PWM) controller. It is not a simple on/off toggle anymore to get the fans on due to the fans running variable speeds now. If you cool the engine under 167° it will also trip a SES light, the ECM thinks the thermostat is stuck open. You would have to turn off reporting on code P0128 to get that to stop, otherwise it will kill some of the gauges until the code is cleared.
I usually go into the calibration thru HPT and change the fan profile myself, I hate waiting until the engine gets over 210° to cool down, but then again I usually also change out the thermostat to a 180° as well.
Yeah, with PWM you need a controller to do the override when you hit the switch, you can't just do it directly. I used a Painless 30140 PWM controller on my Trailblazer and it came set up for that. I'm not sure how you'd rig one on one of these vehicles. But as I was saying, with the engine off mode I don't think a switch is really needed--set the engine off temp pretty low and the fans should come on when you turn off the engine to cool the radiator right away.
I hope somebody comes out with a 180° thermostat soon.
I was just going to ask about that being available, but you answered my question.
I'm taking that running these new engines a bit cooler won't affect anything in a negative way?
I am sure someone will have a 180° stat out soon.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
