Plug wires randomly popping off...
#5 plug wire came off my 2014 Silverado beginning of March. Dealership replaced wire, thought problem was solved. Two days ago the #1 plug popped off driving down the highway.... Took it to dealership and the parts manager shook his head when service manager asked him to order entire new set of wires... Parts manager insisted someone must have been messing with/tampering with it. Seriously? So I returned to dealer this morning and service manager says they just released service bulletin about the plug wires. Anyone else have this happen?
Sent from my HTC DNA using Tapatalk2
I have read posts where this has happened to a few people. Maybe they will chime in. What does the bulletin specifically say or do you know?
No he didn't specify exactly, nor did I see it. Tried searching net. Tbarn said it was addressed in October? They replaced all my wires, so I'm content.
Bulletin released in October says if you find a plug wire off, attempt to reconnect it. If it clicks all is good. No click, replace the wire.
  • 1 year later...
Just had this happen, over railroad tracks, spark plug wire came off at coil on 3rd cyl back passenger side, misfire, engine light and trac light. Good to know there is a bulletin...I will be telling them to give me full set of replacement wires next week.
Called yesterday, they said 35 years, never heard of that, specifically on 2014-2015. After telling them the only option to order new kit, they agreed to check parts dept. and call back. Have message saying they found service bulletin to check clip on wire, but have order full wire kit to be in next week.
As said, check the wire yourself to save some time. Remove it and try to put it back on the plug. If you feel the click it is fine. My guess is someone at the engine plant isn't putting the wires on correctly.
But if you don't feel the click it is not fine. How is that caused during assembly? It must be a defect in the wire end.
Correct, but before you tie up the truck for a day at the dealer.
New wire set has arrived, dealer says they must install (1-1.5hr) for proper paperwork, that's fine...another dept. called right after that and said Onstar update hardware is in, so good time to do both while there.
  • 2 months later...
Is there a TSB for this problem? I've looked around and could only find people having the same issue, but no specific TSB cited. My dealership is playing dumb with it (maybe not playing...). Plug wire coming off twice so far in the past few months. Sure, I can plug it back in but I shouldn't have to!
2014 Sierra 4.3 w/ 15,000
Thanks
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
