Crewcab speaker locations and sizes?
I am in the same scenario. Did you ever come to a conclusion ??
I haven't upgraded my truck yet but I've done a few systems in silverados and sierras at my shop. Most of the info you guys already posted is correct. There are full range 6x9s in the front door, which share signal with the 2.75" mids on the dash, and 6.5s in the rear. The dash mids have caps on them to block the low end. All of this info is for the non Bose system. There's plenty of room behind the seats to mount several amplifiers and processor/eq. There are some 2.75 options, powerbass, Memphis, and a couple others I can't remember right now. All of the ones that we've done have been 6.5 components, with tweeters replacing the mids on the dash. Either making a bracket or some back strap. Door speakers will require plates. We make ours out of plastic, but metra seems them too, but I haven't used them on those trucks. We are a focal dealer so I've done some auditors and some flax series, both sounding great, the flax a better option of course, but for more money lol. We've made all of our boxes for under the seat custom in house, but there's definitely a decent amount of room. Several vendors online offer pre-made boxes that will fight right in. Just make sure you put in the correct can configuration. Hope this helps
Sent from my SM-G930T using Tapatalk
You got speakers? I tried to fade my crew cab to balance the sound only to find my LS doesn't have rears.
Have had subs before - they are really a great addition. Name brand 10" with 400rms is a nice setup. 10 is tighter than a 12 (brand/series compared to same brand/series), and has lots of SPL.
You do want a remote level control for the sub though, as different program materials change up the bass and sometimes you have too little or too much. Overall you don't have to run it like the kid down the block and wake the neighbors to get a great effect - unless you want to :)
Unless your stock setup really sucks, and mine with no rears is still pretty decent - I'd do a sub before upgrading the stock cones.
If swapping anything - 6" subs in rear doors and keep full range in front.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
