Possible short???
thefinchnest
I have spent a year undoing the damage of a 20 year old (previous owner) and have been diagnosing one particular problem since I bought this truck. It is a 2002 GMC Sonoma Crew Cab with a 4.3L engine
It involves the transmission indicator, the transmission, the fuel gauge and maybe more. So here is the typical symptoms my patient is presenting with:
Before the truck is even started Symptom 1: the transmission indicator shows the "P" aglow ever so slightly. (This can only been seen at night) As soon as the key is inserted, the glow goes out. Symptom 2: In some instances, the truck will lurch forward as it is started. Symptom 3: Shifting indicator is slow to respond after Neutral. Shift into Reverse or Neutral and it acts normally. Shift into Drive, 3rd, 2nd, or 1st and the transmission responds but the indicator takes about 5 seconds to respond and then "jumps" to the proper selection. Symptom 4: Whether driving or static, when the transmission is placed in the Neutral position, the fuel gauge will drop showing a level of about 1/8 tank less than what is actually in the tank. When the shifter is returned to Drive, 3rd, 2nd, or 1st, the fuel gauge returns to its proper reading. It is especially problematic when the tank is less than a quarter tank full because the gauge drops as I am driving swiftly until I stop, Park, turn off the engine, restart and the gauge indicates 1/4 full.
Upon changing the fuel pump, I did note the sending unit (electrical measuring prongs) seemingly burned down to stub which I believe was cause ERRATIC fuel gauge responses.
I changed the instrument cluster and the truck presented with the same symptoms.
Replaced the shifter spring (it was broken in half) in hopes that it was causing a faulty ground.
I've found no noticeable wear on the wiring harness, though with the hundreds of wires I could have missed something.
Any techies out there experience these symptoms or have some idea of a particular wire or component that I should be paying more attention to???
Yes, and no codes relating to the transmission and any codes for the fuel and emissions system were cleared with a new fuel tank. (Too many rust holes)
i was a tranny guy for a few yrs and all i can say is ,,,,wow
scan is a great idea ,,,,,have you thought of replacing the NSBU switch on the trans shifter shaft ?,
how about buying service information ,,say alldata for $27/yr
you got some nasty $%#% goin on and throwing more stuff at it and misdiagnoses will piss ME off reading it ,,,lol,,,,the NSBU switch cant hurt is my point in that it is a common failure
internet will only confuse you im afraid ...
please update this as you go cuz no one does lol
I have to agree with govtech. Sounds like the previous owner may have forced on a new one in the wrong position. Although if it is in the wrong position usually it will cause a no start condition. I changed mine because the connector was corroded and when I tried to take it off the whole unit crumbled. Didn't help my problem. Just throwing that out there.
Govtech4- I will look into this switch. Though I'm not sure how this involves the fuel gauge or how it will affect it. The fuel gauge and tranny indicator appear to be related. But yes I will keep you posted.
Badsavana- Though I'm not sure how the switch works, I am skeptical to think that the switch was forced on in the wrong position as I would think that the indicator would show the incorrect position at all times. The case here is that the indicator pauses when it gets to Neutral, and then after a few seconds it "moves" to the correct position.
In the meantime, I'll try to post a video of what I am encountering, if I figure out how.
Thanks for the input.
Fuel gauge has nothing to do with transmission NSBU switch ,
The NSBU switch can be bear , sand the end of the shaft as it can get flared out from the nut , it's is oval (2 flat sides) so lining up the new switch very important .
Get a deep socket that just fits the shaft to help press on the switch be VERY carful , abit of lube never hurts as well ,
This may take care of one of your issues but not everything ,these switches don't like moisture , as said they are a common failure point
Make sure that the tang that comes installed on the unit does not fall off before you have it installed. Also the trans needs to be in neuteral. As stated be very careful.
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 799 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
