Pioneer DEH-P77DH installed
Got my unit installed today.  Tommy Likey!  :D
Here's a rundown:
Pioneer DEH-P77DH Head Unit - $215.00 (incl S&H) from Etronics.com.  Ordered Saturday morning, recieved Wednesday.  (The price when I bought it Saturday was $199, now it's $209)
GM wire harness -  $5.00 from Crutchfield.
GM mounting kit - $8.00 from Crutchfield.  Ordered both Saturday morning, recieved Tuesday.
GM antenna adapter - $5.00 from Crutchfield.  I already had one, so I didn't have to actually order one.
Stereo looks great dude good job :thumb:
What do you have around your gauges and were did you get it at?  That looks pretty good also from what I can see from the pic..........
Thanks.
Cowboy,
I just took the trim off that goes around the gauges and painted it silver.  You have remove the clear lens from the trim, then glue it back on after it's painted. :cheers:
Nice pics...
So I guess the Crutchfield plastic clip/brackets attach directly to the head unit? What size screws are used to attach the brackets to the head unit? Did the holes on the head unit line up with the bracket holes?
Thanks...
Nice pics...
Thanks...
Crap, I forgot I told you that I'd let you know about that.  :cheers:
The head unit comes with a bag of nuts/bolts, etc.  I'm not sure what you call it, but it's a bolt that is attached to a little clip-looking thing.  You snap one in the slots on each side of the head unit, the Crutchfield mounting kit had a couple plastic tabs that slide into slots near the front of the head unit.  You then lay them down flat and the hole in the mounting kit will go over the bolt/clip-looking thing.  Use a nut that is supplied with the head unit to attach the back part of the mounting kit.
The wiring harness from Crutchfield is color matched with the harness that comes with the head unit.  Just need to solder/crimp the correct colors together.  I soldered and then put some heat shrink over the solder.  There was a couple wires that I didn't use.  Power antenna and cell phone mute, I think.  I just capped them off with some heat shrink.
I also didn't hook up all the alarm, door lock, security features either.  i may sometime down the road though.
Hope this helps.  :flag:
  • 1 month later...
I have the same unit!  I'm extremely happy with this, and the ease of install makes it a great idea for those wanting a better deck but not wanting that extra space that is left by the smaller din sized head units.
I took it one further, and swapped out all the speakers.  I replaced my tweaters with some Infinity q's and got some Kicker Mid Bass drivers for the 6 1/2's in the front doors, and the infinity plates for the back pillars (I have a reg cab.)  I then wired the mid subs up to a RF 150watt amp.  I Then turned on the FIE (Front Image Enhancement) and bam!  Instant crossover.  Sounds very crisp and clean!
  • 3 weeks later...
Hey!  That looks familiar!! Sorry I never got pics of mine up way back when you were asking about this HU.  I've been very happy with it, and for the money, there is absolutely nothing that comes close.  Look how many HU's change styles and what not almost every year, and the deh-77 has remained unchanged for what, 4 years now?
Looks good!  :thumb:
toddoughty, thanks.   I just painted the surround, that's all.  :)
Thanks Henry.  No, it's not XM.  Your's looks pretty nifty.  :thumb:
No, it's not XM.
Yes it is.  I spoke to Crutchfield as I'm thinking of getting the same unit.  The unit will accept an XM satellite through the IPBus using the Pioneer GEX-P900XM tuner ($119) and the correct cable.  If you have a CD Changer,  you can then plug the changer into the XM unit in a daisy chain.  You can control the XM unit but you may not get all of the display - my guess is it won't scroll text.
FYI :chevy:
<font color='#000000'>
No, it's not XM.
FYI :chevy:</font>
Let me re-phrase.  The head unit alone is not XM.  :cheers:
  • 2 months later...
I had this unit in my old dodge and I am considering putting it in my brand new Avalanche, Yes it does accept XM, and yes it doesnot scroll the text, but the sound is a lot better then if you had an RF adapter.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
