60k. Groan/squeak is still there. Better or worse on any given day. Guess I've gotten used to it. What's funny is the 114k mile '89 K5 in my aviator does not have a squeaky groany pedal. I might try pulling the boot back and putting some grease on the linkage like a user on another forum did on his truck.
Edited by FL335i
So infuriating that the brake pedal squeak and flapper valve chirp are being labeled as "normal" conditions. I've given en up getting a resolution so I have to sacrifice mileage by keeping the valve open or buy a new exhaust. The brake squeak is so bad my family doesn't want to ride in my truck as it is so annoying. After 7 GM trucks, I'm moving to Ford on the next go round. Frustrated!!
Sent from my VS995 using Tapatalk
  • 7 months later...
I have a 2015 Chevy suburban with the same problem. It only has 40000 miles. I love paying 60,0000 dollars for a vehicle with a squeaky brake pedal.It's out of warranty so I'm sure they will chare me 250 dollars just for them to say yup you have a squeaky brake pedal.
I have 71k on my truck now. Some days the pedal squeaks, other days it does not. Not terrible. My wife's '15 Enclave has 30k on it and the brake pedal does the same thing. Squeaks when you press on it. 2 for 2.
Just purchased a 15 Sierra 1500 slt with 13600 on the clock last Monday...have the same squeaky brake pedal noise...was gonna spray the bushings with some white silicone to see if that fixes it...don’t wanna bring it back to the dealership...owned it for a week and brought it back for a loud blower motor (ended up being a leaf in there) and got the truck back with a scratch on the passenger rear...called them and they gave me a hassle so I fixed it myself...now I have 2 years of free maintenance and a warranty that’ll probably never be used again...I guess even big name dealerships suck too lol
Same  annoying and frustrating problem here.  I’ve had the brake booster replaced twice on my 2015 Chevrolet Tahoe LTZ and still have the problem.  I’ve been a GM man for the last 35 years,  but seriously contemplating seeking a different brand.
  • 10 months later...
Hi, My 2015 Silverado with 18K miles just started doing this also (Squeaky brake pedal) especially on humid days. Chevy dealer will be replacing the brake booster tomorrow.
Quote
Edited by Ray W.
2014 sierra with same issue, dealer replaced booster under warranty and good for a wile no its back all the time and no warranty.. the booster is cheap labor will be more but to get the noise again will suck.
Jeep Wrangler Jk's have this same issue with the potentially the same "resolution." I had the brake booster swapped on the JK and it was quiet for a few months then came back. So I suspect that those who say they will leave to a different brand will be surprised if they make their way over to Dodge.
Replaced my brake booster and problem solved!
I had a Jeep Wrangler with the same problem. After two failed fixes, replacing the brake booster was also the solution for that.
  • 8 months later...
We have a 2013 Traverse with the same squeaky brake pedal.  Dealership says that is normal.  I told him it isn't normal as I wouldn't have bought it making that noise.  Then the other person in the dealership (a woman) stated that it has happened over and over and there isn't anything that they can do for it.  Come on GM, I have had Tahoes with 250K+ miles that it never happened in, Silverados that it never happened in, I have a GMC 2500 that it has never happened in....  What gives?  It's like fingernails on a chalkboard, this needs to be fixed.  The dealership shouldn't be telling people basically "oh well, live with it"
Edited by Howie623
duplicated sentence
I have a 2015 Chevy Traverse and every since the dealer did the fluid flush the brake pedal has been squeaking. They told me there was a couple of service bulletins for this issue but I think @ $120.00 is to much just to be told what to do when they should know the problem by now.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
