Air Bag Scan Codes
bigbipper
Your charging system appears to be ok based on the voltages you are seeing. About all you can really do is verify that all connections in the air bag system are clean and tight.
Boosting a vehicle that has a completely dead battery can create issues with some of the electronics. Personally, I have never had any issues, or seen any issues first hand, with damage caused by either incorrect boosting procedure or by the dead battery causing a surge. To me, the only way I can imagine any damage being done by boosting a dead battery would be if the key was not in the off position on the dead battery vehicle when cables were connected with the boosting car running. If key was off, I don't see how any circuits that are inactive with key off could be damaged. This is based on how I troubleshoot electrical issues.
Is it only the air bag circuit that you are trying to correct? Does your truck have a switch for disabling the passenger side air bag? Have you tried clearing codes, and disabling passenger side air bag, and then see if both codes come back.
Doug, as always, thanks for your reply and concern.
At this point the only circuit that appears to be compromised is that of the air bag.
I have not tried what you suggested, but will try this evening.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
    • For most of you, this is probably outside your realm of interest, but, maybe you can appreciate it. The hood and wheels aren't something I'm interested in, but someone made a very rowdy Audi S4... amazing sound.       These were/are very fun cars for the money.   Not going to lie, I'm getting an itch to own a newer Audi RS3. The 5-cylinder will be changing, or going away, at the end of this year.
