2017 here service 4wd allmost every key start or soon thereafter.
dismiss message, everything works just fine.
I'll wait to drive an hour to dealer until something is really wrong.
have you ever figured this out on yours?
Yes it was a pushed out connector on the harness.
Ugghh, figures. They've already replaced the harness on mine and its still doing it.
I will say, mine doesn't happen every keystroke, it waits about every 2 to 3 weeks before it decides to come on once I dismiss it
Thanks
Edited by T_ClarkEx39
Thanks
also had problems with the 110v  port in console, also a pin problem in the same harness connector.
I will have to check that out. I never use that 110 volt port so it may or may not be working I wouldn't know
  • 10 months later...
Got this message a few times this morning on my 2016 with 25k miles.
Didn’t seem to have any issues attempting to change between 2 and 4WD....
  • 5 months later...
  • 4 years later...
I have a 2015 GMC Sierra 4wd with 244,000 miles. Over the years I’ve had the service 4wd message. I’d dismiss it and all is fine. Last night it came back I dismissed it and tried selecting 2wd or 4wd and it won’t do anything. I suspect a low battery because everything was acting different with the transmission. Wouldn’t go in gear forward or reverse, after several attempts it went in drive. After charging overnight everything seemed fine except transfer case wouldn’t move out of Auto position. Anyone else notice these batteries only last about 3 years?
Before I replaced my battery, when it would run out of "juice" and I did a scan, all kinds of errors ere present.
The MyChevy app would tell me every system needed attention.
I found I had a battery drain with my Dash Cam, once I got it sorted, no issues, the old battery might have been good all along.
Most batteries should easily last 5 years or better if you don't have a parasitic power drain somewhere.
Any idea where the X-1 TCCM connector is located. I can read the Service Bulletin, but there's no pics.
    Pumping Pete
    Pumping Pete
  • Who's Online   4 Members, 0 Anonymous, 835 Guests (See full list)
