So you only need that kit and an extra battery and your all set?
it is very easy... you really need two wires and a battery.
The kit is just a nicer better way to go.
If you just connect another battery to your existing one, won't that give you 24v instead of 12v?
no...
not if you do red to red and black to black.
Red to black, black to ground will make 24 volts.
Google: Series and Parallel wiring.
Edited by frenchsquared
Only wired in series. To have a deep well 12v, you connect the positive together and ground in the same place. To make 24v you connect pos to neg between the batteries
What gauge wire would you suggest and also battery to do this?
I think factory wire size may be 8. I would use 4. 1/0 if you have a 250+ amp alternator
You definitely want the computer controlled relay to isolate the systems especially if you start having problems.
Two batteries is not a new thing. I would get the kit just so one does not drain the other.
However it wont effect the ECU at all. Talk to anyone into hydraulics or look at any semi.
Guys have been running dual batteries for as long as batteries have been made.
Stereo guys do it as well. Red neck way to stop head lights from flashing.
You need to match your batteries at the same size(cca) so that they charge / discharge evenly. If you put different sizes in it can possibly cause problems.
    250.6k
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 424 Guests (See full list)
