I'm not quite done yet, still need to hide some wires on passenger side under the carpetm here is my progress. I have now spent over 5 hours taking off old electrical tape, zip tying, and putting on the powerbraid, and hiding wires. I have a nice stack of crap I have pulled out, including the head unit for the aftermarket stereo. I need to buy a dash block off plate now.
Before:
After(wires on left not done yet):
Halfway through:
After:
Edited by SnakeEyes
Car seats ready for transport to the show tomorrow
Detail spray loaded
Ryan
Before:
Halfway through:
After:
Nice work. Looks much better.
Thanks. Forgot to get a before shot of the spot in the engine bay. Looked like a crayloa box exploded once I had the electrical tape off. The tape did its job, but was getting old, looked bad, and the stickiness was literally melting off, making a shiny goo, that was a pain to wash off when you touched it.
Well crap, have to figure out where that frayed disconnected wires goes. It came off the driver's side of the trans near the front
I found the connection I pulled apart. It was stuck in carpet glue so when I pulled the wires out for the powerbraid it came loose.
Two good stories today. Pulled into a Braums parking lot this morning in the early am when troubleshooting. When I climb out of the footwell an S10 is RIGHT THERE. I jumped and the guy was like "OH! Sorry, just wanted to tell you its beautiful!"
I guess he had followed me in the lot.
On the way home, a ram is next to me for 4 blocks, I think nothing of it, every time I drive it this happens. Mind you the OD is off so I'm at 3100 RPM with straight through mufflers on a 541 V8. Then I notice their window going up.
Sorry Ram 3500 wasn't trying to snub ya, I just didn't hear a thing. Still can't, actually
Day started off cold (40s) and rainy but ended sunny and mid 60s
The dealer putting on the rally had a nice Tahoe. Loved the color. Price tag for the LT version (Leather, rear dvd basically fully loaded LT was $59K)
Car also rolled over 4K miles today
Out of the 100 or so cars mine was the only Ashen Gray
Next mod?
I even got my daughter saying "supercharger" haha
Ryan
2014 hood with the functional heat extractor vents. Have the vent color matched. Will be easy to match paint since yours hasn't seen a UV ray.
Edited by SnakeEyes
I am really considering this as it gets hot under the hood. Guy in our club just had his done
Ryan
I was going over the botched dyno session story with a coworker(Ford guy), was telling him about the strange timing setting I found on the ignition control box.
He was thinking maybe a previous guy had done that when the starter was starting to go, he said it can help it fire up quicker. He's a hard core mustang guy, has a 65, and a 03 Mach1 that I wouldn't be surprised if it kept in a climate controlled bubble. He looked it over for 15 minutes and said "everything looks right", was impressed.
He has a Sprint Car, and said he has seen around 70HP differences on it with just a few degrees of timing change, so he thinks I picked up a lot of power when I removed the retard the day after the dyno. He agreed it probably is over 700HP like I originally thought. That stupid dyno had me so worried before I found out it was botched.
Its been getting me thinking about getting that custom billet cam from Straub, he was sure he could get another 100 RWHP.
Edited by SnakeEyes
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,127 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
