Don't know if I am following this, the Tahoe LS, LT and the Yukon are the least expensive GM Fullsize SUVs. But if anyone of those trucks were taken to the dealer and asked what could they mod, the only thing that would be a problem would probably be the 6.2 and the Mag Ride, everything else is pretty much plug and play. Which would make these trucks the same. If that's the case all should have ANC. If not, based on your test the least expensive models should therefore have crazy road and wind noise. I have a LT, my RPO code says my truck came with ANC and I have no road or wind noise.
What's interesting about the fact your LT has "ANC" is that based on the online specs and features, none of he Chevrolet models come with "Active Noise Cancellation". The term is not used anywhere for any of the models. And, doesn't show up as an option in the build section. Now, I realize the website isn't the final word, and the dealer system is different and will build it based on what GM will allow. But, in contrast, on the GMC website, "Active Noise Control" is only used in one place - as a standard feature in the Denali versions.
Now, both Chevy and GMC show that the 9 and 10 speaker Bose systems include the "AudioPilot" Noise Cancellation feature.
So the big question is - is there a difference between and vehicle with the Bose system c/w AudioPilot, and a vehicle also with "ANC"?? More importantly, does it matter? I say not. I drove a variety of rentals, with and without the Bose system, and all of them exhibited the buffeting. So, I'm pretty sure it's irrelevant. At least as a cause.
"My Yukon is a stock 2015i short Denali with the only option being the 2nd row bench. No sunroof. 20" wheels with Continentals. 6.2L/8-speed"
For the record, my daily driver is the same but with the sunroom and crossbars.
Do both of your trucks have factory crossbars...and neither have the buffeting issue? Have you been in one and have noticed the buffeting?
Edited by ajs800
No crossbars on mine, but I will buy a pair by March.
Me: My Yukon is a stock 2015i short Denali with the only option being the 2nd row bench. No sunroof. No crossbars. 20" wheels with Continentals. 6.2L/8-speed. Buffets/vibrates/booms.
Related ongoing thread on this site, in case you haven't seen with 6,100 replies and 680K views...
Marc
Note: In addition to the consumer magazines, each of you with this problem should submit your problem to BBB Autoline and the Federal Trade Commission (yes, they do want to know).
Let me add some input on this. GM/GMC has done several things in the past 18 months, which are unethical, and in some cases illegal. Two examples (most commonly found in this and other forums): (1) these vehicles have a problem with buffeting which has caused headaches, makes many unable to be in the vehicles, and caused symptoms of vestibular disorientation ... in the best case, discomfort and in the worst the disorientation, need to vomit, and severe headaches could be a distraction leading to an accident; and, (2) continuing to market the vehicles as having a lay flat cargo area which it is not, leading to items falling out of the vehicle when the tailgate is opened and, in one case, a heavy item falling out and causing personal injury. In both of these examples, GM/GMC has (a) acknowledged these issues, is continuing to advertise, market, and sell the vehicles without warning consumers of the potential problems; (b) has no solution to either problem; and (c ) is unwilling to take back vehicles with complete refunds to consumers or in many cases, simply doing nothing except perhaps offering a $250.00 to $1000.00 coupon to purchase accessories (for a vehicle you don't want to keep).
Unless GM/GMC starts getting pressure from BBB Autoline and the FTC, they have absolutely no incentive to fix the issues or, in some manner, compensate the owner, or replace the vehicle (no charge to owner).
My 2 cents only.
Edited by Anon2015
"Now, both Chevy and GMC show that the 9 and 10 speaker Bose systems include the "AudioPilot" Noise Cancellation feature. "
AudioPilot and ANC are two different beasts. Active Noise Cancellation (ANC) is an effort to reduce cabin noise and can only work effectively at low frequencies (a function of cabin size and seating area size). AudioPilot is an attempt (a poor one at that) by Bose to increase the intelligibility of (in particular, speech) sound from your radio/audio system. It measures cabin noises by frequency and then boosts those frequencies masked by cabin noise.It does not work across all bands and its effect is very difficult to discern...and difficult to detect without some rather sophisticated analysis equipment. Both were developed by Bose.
Magnetic Ride Control was developed by GM and can be found in the Audi R8 and Ferrari. Bose has also developed a much more sophisticated Magnetic suspension. There were rumors Bose and GM collaborated on the system use in the Yukon Denali and Escalade. Based upon performance, it would appear to be just that --- rumor. Also based upon performance it would appear to be the older single wire system rather than the two wire system on the Corvettes...I guessing on that however.
Edited by Anon2015
So the big question is - is there a difference between and vehicle with the Bose system c/w AudioPilot, and a vehicle also with "ANC"?? So, I'm pretty sure it's irrelevant. At least as a cause.
The gen 2 and 3 Chevy Fullsize SUVs did not come with ANC and did not have the buffeting and pressure. Then the new gen 4 comes along with higher and thinner metal panels, more hp, and performance car suspension. Some of which I believe allows for more cabin noise and pressure. GM knows about this from the onset and what do they do, incorporate ANC to manage the cabin noise and pressure. I agree ANC is not the "cause", but I believe it was put in the new gen 4 trucks to be part of the "solution".
What did you get ?
Went back to a pickup. 1/2 ton Silverado. I do a fair amount of towing and the booming sound seemed to be amplified with a trailer attached.
Looks like I'll be doing the same with our 15 xl slt...I may test drive a few suburbans or another xl but will most likely go back to a pre 15 model. Haven't even had it 2 months and I can't stand to drive it due to the buffeting... Headache and ears popping within 20min. Have been trying different things in hopes of finding a solution but no such luck. I still can't get over the fact a vehicle built today can cause such discomfort especially at this price point. I find it hard to believe, given how many I see on the road, that they all have the issue.
For those of you that own one with the buffeting /pressure problem , have you driven one without the issue?
Edited by ajs800
For what it's worth, here is an update on ours. I don't drive it regularly, but I did drive it yesterday and today. To me, it seems there is virtually no buffeting on the highway (100-110 km/hr). At lower speeds, there is still the very noticeable boom sounds. Now, we've got about 20,000 km on it, so one must wonder if the buffeting is getting better over time. But, the vibration in the steering wheel and the boom sounds over sharp bumps in the road and at lower speeds still every bit as severe as it always was.
Anyway, thought I would share that.
Hi all,
I've put another 1,000km on the odometer since my last post with about half that had me driving more slowly pulling a trailer. 115km/h and 65km/h [71mph and 40mph] are definite sweet spots for me. I didn't have much weight on the trailer and didn't notice a difference w.r.t. the boom.
I do not notice a vibration in the steering wheel or the pedals as some folks in the Silverado/Sierra forum do. I may feel a little in the driver's seat. Maybe my ears are more sensitive than my seat-of-the-pants-o-meter...
My Yukon goes into the dealership on Thursday to investigate the vibration/boom. And to diagnose why the wireless charger randomly stops charging...
Marc
The 6 hour road trip this past weekend in the Denali was not an enjoyable ride especially above 65 mph.
Towed the boat (Ski Nautique) to storage today. No booming, buffeting or air pressure issues. Smooth ride and quiet! Maybe I should just leave it hooked up throughout the winter!
Going to buy then try roof rack cross bars to interrupt the air flow across the roof to see if that will help with the booming and buffeting.
Interesting.....I experience a ton of body booming at slower speeds on rough roads. I notice little or zero booming on the same roads under hard acceleration (i.e. when accelerating from a stop sign or traffic signal).
The hard acceleration makes the truck "squat" in the rear and loads the rear suspension. The weight of your boat and trailer do something similar. I do think the rear suspension is part of this issue.
Edited by yukontruckman
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
