Problem pop clunking noise 1999 Seirra
Thinking about buying this truck but there's an issue truck starts sounds good in neutral pit into gear still so far good start driving there's a popping and clunking noise you can feel under the floor and the truck seems like it's being held back sort of until you get the rpms over 1500 then the noise goes away and it seems fine until you shift Into the next gear the rpms go back downa an it does the same thing till revved back up transmission seems fine truck is 5 speed with 4 wheel drive if anyone can tell me what this is it'd be greatly appreciated
Sounds like a bad slip yoke possibly? I get a little jolt under slow acceleration or while turning because the splines get rusty and then it binds up. It makes a clunk going into gear. Or a worn transfer case.
Well I don't notice going into gear because it's a standered is there anyway I could seperate the two anything major I might notice that I should know if it's the TC or the slip yoke
Put the rear end on jack stands, chock the wheels, have someone give it gas, listen/look under vehicle for cause. That will help pin point
Better have a really close look at the frame of the truck, especially where the body mounts are located. This sounds to me like you might have a broken frame rail or crossmember somewhere...yikes!!
Is it possible it's just a really bad u joint lol I'm checking it out Tommorow just wondering what to look for I did look all cross members good and no cracks or anything
In the frame
Or I was thinking a bad slip yoke even I just don't want it to be somthing to exspensive under 400 dollar fix hopefully also I have a miss fire but only when revved up any ideas on that?
Almost for sure a u-joint. Cheap fix, do both. I drove from Detroit to Calgary with a bad one. You keep tension on it and it will stay quiet. Take the pressure off and it thumps like mad. Light brake will help with shifting. You have 4 wheel and I had 2. I'm not sure of the configuration of the front end but it sure sounds like the rear drive shaft to me. They are cheap, less then $20 each. Watch the rear grease nipple, my 2001 you have to drop the shaft on the ground to grease it. You can't get the grease gun on to it when the shaft is installed.
If it is the slip yoke gm has an updated version made from nickel. Service bulletin #01-04-17-004B:
Hopefully i can get one, .... One day
Alright well I'll take a look for everything you've all mentioned taking it into shop today so I can get it on a lift cross fingers hope it's not somthing big thanks for all your help
Got truck up and found the issue barbed wire wraped up stuck in the front universal all that's left is a misfire and I've decided to purchase the truck
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
