My 2014 has what looks like rust/brownish on aluminum polished wheels. Also they look foggy. What do you use to clean yours wheels polishes, buffing compounds, sprays, and/or sealants?
If you have pics that would be good... "Rust/brownish" sounds like brake dust. (but really hard to know without pics).
If the wheels are polished aluminum, they would be clearcoated. Start with carwash soap and water. If that doesn't work, try claybar. Next I would try Meguiars Ultimate polish on a microfiber towel or Meguiars 105/205.
Edited by Luster
Aluminum isn't going to rust, I'd have to agree with brake dust.
Whatever you use, make sure you don't use something that is too strong (like purple power). It will turn the clear white.
If you can't get it to come clean take it to the dealer, have them warranted
Edited by Cmillerjr
My High Country wheels had white/hazy spots on them when I took delivery and had the dealership get me 4 new flawless wheels and tires. It looked like somebody in "clean up" sprayed something too harsh on them and didn't wipe it off between the spokes. Not sure if it happened from the GM wheel manufacturer or after the truck was delivered to the dealership.
I tried wasing and waxing it does nothing. if anyone has the same wheels please post pics. I just feel they should have a better reflection then this.
The wheels aren't chrome, they're polished aluminum, so the shine/reflection looks exactly as it should... except for the brown spots. Have you tried clay-bar?
Steel wool (0000 grade), and a good foaming glass cleaners works well.
Won't that leave little fine scratches?
The wheels are clear-coated, so treat them just as you would paint. I would try claybar, then Meguiars 105 polish. Steel wool will scratch the clearcoat. (steel wool would work if they weren't clear coated)
I finally got some sonax wheel cleaner safe for all wheels. After use it just wipes right off. I was amazed as you could scrub with soap and water that did nothing.
Just picked up a set of these wheels myself, if anyone has used that tutorial I'd love to see before and after pics.
Edited by webhead
Do not get aggressive and polish off clear coat. The clear coat is tinted vice clear. I used a Dremel to smooth out small curb rash, polished and touched up clear coat after sanding with 2000 grit. Repair was perfect but the clear coat afterwards left the spot a brighter color of aluminum compared to original.
Edited by GMCSierra4x4
It is a polished, clear coated wheel. Treat it just like you would your paint. Don't listen to the other guys telling you to use stew wool.... Get it good and clean, and try a clay bar first. If that doesn't work, use a least abrasive polishing compound and go from there. Make sure to use a sealant when you are done also.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
