2014 Silverado radio, is this normal?
Bobk54
I'm new to the forum and hope someone can shed some light on this. Whenever I start the truck the radio comes on, even if I shut it off prior to shutting the engine off, On the next start the radio comes on again. I'm talking about actually shutting the radio all the way off, not just muting it. I shut the power off and a big blue analog clock shows up on the radio screen but the next time I start it up the radio is on again in the standby / muted mode. I can't find anything in the manual or the internet about this. Anyone else's radio acting the same way?
There is no way to fully turn the radio off. It's strange.
But you can adjust the "Maximum Start-up volume" down to zero so that its muted or at least very quiet, when you turn on the truck. Its a setting somewhere in the menus.
Sorry, I left that part out. When it comes on after starting the engine it's already muted if I previously shut it all the way off. I've already set the start up volume for when I don't shut it off prior to stopping the engine, then it comes on like I would expect it to. I guess If that's the way it works it's acting normally, just seems odd to me.
  • 7 months later...
It appears to be working properly. I have never tried to set the max start volume to zero but mine is set very low for when the truck starts. The "power button on these trucks is essentially just a mute button even though it does power off the majority of the radio. I found this confusing too the first time I put my programmer in my truck.
Yes they run more like a computer/tablet now so it's always on.
So if you need to reboot it you have to pull a fuse or disconnect the battery.
I just did this as the radio would not shut off. It stayed on past the power retention, wouldn't turn off with the doors or key.
So I disconnected the battery and it hasn't happened since.
Just FYI the radio's are a little buggy...
Mine stays off if you turn it off to the point of seeing just the clock as you stated. I turned it off yesterday and restarted the truck several times including this morning and it was still off not just muted. I have the 4.2" screen.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
