Need help using VIN to get build info
I am in the process of purchasing a used 2014. However, the window sticker is long gone, so I have no way to determine what is all on this truck for a better apples to apples comparison.
Any way to punch the VIN in and get this info? (gear ration, standard or short bed, option, locking diff, etc.?)
Thanks!
Thanks!
As thefishhawk mentioned, we'd be glad to assist you with a build sheet for this vehicle. We'll just need the VIN and an email address to send it to. We look forward to hearing from you!
Andraya
GM Customer Care
Thanks!
If you have access to the truck, the RPO codes will be on the label in the glove box.
Trim level, engine option and 2wd/4wd will also help in identifying options which may be standard.
