Helo wheels
MD Chevy
The link just takes me to tirerack's home page, rather than a specific wheel, so I'm not sure which wheels you're referring to. Also, we need a little more information to help you. What kind of truck are they going on? Year, make, model? Any suspension mods? Tire size?
Not sure why it didn't work. They are the HE835. Right now I have nothing done to my truck but will eventually level it and go with the biggest tires I can without rubbing. They will be going on a 2014 double cab 4x4.
Gotcha. Well the 20x9 and the 18x9 both have a 5.67" backspacing and +18mm offset, so you'll be just fine there. They'll probably be just barely tucked in the fenders still. I've got 18x9, +18mm offset rims on my truck, and they sit just about flush with the fenders. I think the fenders on the new body style trucks are a bit wider, because the new factory rims have a slightly less positive offset then the previous generation. Those wheels with a 2"-2.5" level and some 33's will look really good. And, if they're not hub centric, they should include centering rings that go between the hub and the rim to make it so. I had to use those on my last truck, and they worked just fine.
Ok. Thanks for the help. The ones I am looking at are used for about 400 miles. They are 17x9. What's a decent price to pay?
Ok, well if they're the 17's, then they're only a 17x8, with a 4.53" backspace and 0 offset. That's going to push them farther outside just a bit, and may limit you a little on tire sizes. Are they the chrome ones, or the black/machined ones?
They are the black machined ones. What would be a size tire I could put on those without rubbing?
If they're in really good shape (which they should be with only around 400 miles on them), then I'd say somewhere around $400 would be a good price, including lug nuts and center caps. You should be able to run a 285/70/17 with a leveling kit on those rims, without any problems at all. A 295/70/17 might even fit.
That offset is the issue. It pushes the wheel out 1". You can just subtract 2" in tire section width from the max width that would fit with the 5.5 to 5.7 backspace. So my take is a 33x10.50 will be about the limit without rubbing at full lock.
This is why I want to stay with an OEM wheel. Thanks guys, I'll just wait for a good deal on some stock wheels!
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
