Ordering a 2015 Silverado
As I was going through the options with the Sales Manager, I asked about the Borla exhaust option. He said he hasn't heard of that option, and said it must be a dealer install option since it wasn't on his computer. Can anyone provide some insight?
It's a dealer install option. They'll just order it and install it for you. But, my opinion is that a Borla cat-back exhaust isn't worth the $1,200 the site says and that's not including the cost of install. Just have a shop that does custom exhaust do the exhaust like you want it and they can do what you want for less than 1/3 of that price.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
