Wheel tire size
A 33x12.50 will fit without any lift with 8.5" wide 5.5" backspace wheels ... barely. If using a 9" wide wheel, a 5.75" backspace (+20 offset) will be the most centered in the well. I recommend you measure before you level, unless you don't think you'll ever compress the suspension with the wheels turned. Measure by turning and holding the wheels at full lock both directions. Add width and diameter to your existing tires. Add/subtract for wheel offset changes.
A 2" level really doesn't give you much more clearance. The wheels still go up and down.
