Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
I told you in your other thread all you need is a 6mm spacer. You don't need extended lugs either with the 5mm spacer. I really don't like extended lugs as they don't seat in the wheel if the studs are tight in the lug holes.
The spacer size wasn't a guess for me. I had a set from a 2016 truck on my Avalanche and someone on this forum asked if they would fit a 2019+ truck. I test fit one and it didn't work as is. I had a 6mm spacer I was using for my summer wheels since they are aftermarket and didn't clear the calipers and the previous gen OEM wheels fit just fine.
