Need converter advice
A 3200 stall on a daily driver will make you hate life. If you want to be able to spin the tires, there are a lot of better options than stalling the living crap out of the truck.
  • Replies 57
I need better of the line this suburban is soooo slow 0-30
Gear it, my Yukon XL with 5.3 and 205,000 miles will still spin the tires if I stand on it from a stop. Mine has 3.73:1 gears. You put a 3200 stall in it you are not going to accomplish what you are trying to do. You will hinder towing for sure
I dont tow at all i drive 80% highway and i have 3.73's and blackbear, k&n and cannot spin them with 126,000 miles lol. I was told that under light throttle it would drive almost the same after proper tuning but when i step on it you will notice a lot more. Im fine losing 1-2 mpg city
Just a comment/question but why do you need to spin tires, especially in a Suburban? If you're spinning tires, you just burn tread.
I like the idea of having to power to do it but more importantly its a total dog 0-30 and thats where i wanted the most gain so i thought it would be a good idea since i needed a new converter. All the reviews sorta talked me into it
Guys the trans shop just called me and said to re think on the 3200. They told me way to much heat which i know (plan on trucool) and he said the vehicle would stall out over 3200? Would i get the same response or power gain off the line with a 2800?? I need to call him back in an hour
Buy a supercharger
So what if I already have a supercharger installed? I'm planning on a performance upgrade for my tranny in the spring and I'm at a loss for which way to go on my converter choice. My truck is a 2008 1500 4x4 LTZ with a Roush supercharged 5.3 with longtubes and GMPP(borla sport) cat back and Blackbear tuned with 3.73 gears and 33" tires. Any help would be greatly appreciated if anyone would care to, Thanks.
I canceled my order. I will be doing something in the 2600-3000 range and blackbear finally got back to me!
Did they tell you to go lower? For daily driven on stock cam look in the 2600-2800 range.
Yes thats exactly what they said. I hope its enough stall, i like the idea of 2600-2800 over 3200
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
