Where can I buy black window sills for 2014 Sierram
My new ones should be in this week. I'll install them next weekend and get back w you. I want to make sure I don't break a clip before I give you a price. I have the door handles and mirror caps Akso if you're interested in those. Thanks again for the help never-rested!
No problem. Thanks!
My truck came with chrome everything except the window trim. I rarely see it on the silverado.
Just let me know on those chrome sills, very interested.
Thanks!
How did you end up? Willing to sell the chrome?
Thanks
I have the new ones and they appear to be right. Do you know how to get the back ones off? I'm pretty sure there at least one screw to remove but I can't find it. I'm thinking it's hidden behind a panel. I've already changed my front ones. Yes, I'll definitely sale them.
Just a quick search returned this:
installed mine today took a total of about 5 minutes to put them on. removal is easy once you know how it works. ill get some pics up tomorrow as I was at work for most of the day.
step 1: roll down all the windows.
step 2: remove torx screw located in the door jam towards the rear of the doors on the front two doors (torx screw is on the front of the doors in the door jam on the back two doors. you have to pull back the weather stripping a little bit to see them. to pull the weather stripping back the edge is help on by a body pin. I used dikes and a towel so I didn't scratch the paint when prying the body pin out. then pull the weather stripping back like 2" and you will see the torx screw.)
step 3: using a long but thin flathead look between the window and the trim and you will see some white clips. you will have to use your fingers to pull the window back a little to get the screw driver between the window and trim in order to get to the clips. there are two grooves on the bottom of the clips (kinda like hooks) put the screw driver in there and pry them back towards the window and at the same time pull trim up. repeat this step three more times per trim (total of 4 clips that are evenly spaced out).
step 4: once all the clips are out, pull the trim towards the back of the truck to get it out from behind the mirror and it will slide right out. for the back doors trim I believe it is opposite when sliding the trim off or it may just come straight up.
step 5: do the exact opposite to reinstall the trim.
WARNING: do not try and force the trim up as the clips "lip" that hold on to the door is very small and can be broken very easily. pry on the clip bring the bottom of the clip towards the window and if it is fully released the trim will come up very easily, no force needed. also becareful when using a metal object to pry because im sure you cold potentially crack, chip or break your window.
This is the thread: http://www.gm-trucks.com/forums/topic/157086-window-trim-moldings/page-3
Not sure if it helps.
  • 3 months later...
I have all chrome on a 2015 Sierra Crew that I would love to trade for black.
  • 2 years later...
