lug nuts for sierra 1500 2WD
chevroletgm
hello just wondering what is the appropriate lug nuts for the vehicle for this type of rim I have attached here. Its a 6 Lug sorry for the photos are from google. If I can please have the part number Thank-You
I would try using the ones already on your truck. If the center caps couldn't fit due to the length of the lug nuts, then buy a set of open-ended acorn type. I believe the thread size is 14mm-1.5.
Those should work. What diameter is the wheel? If it's 16", you might want to check clearance with the brakes. The sizes have been increased in each generation and that wheel looks like it's from GMT-800.
Ah, so you have a GMT800. For some reason I thought you had a K2XX.
Test it first, but I think Those lugs would be too tall and the smooth caps won't fit. Test it first. You will need the ones that are shorter and do not have the threaded section on them to fit under the smooth caps that don't thread onto the lug nuts. GM number p/n 9595174.
Hello, how 100% sure I will need these GM number p/n 9595174.? but ill get them anyway just to be safe
Almost twice as tall. Best way to be sure is to test fit a wheel with the nut with the threads and see if the center cap fits. The cap is retained via the wheel. I wish I had two caps to compare. Auto parts stores will have them as well, Dorman p/n is 611-110.
