I pulled the trigger.
As the title says, I pulled the trigger on a new (to me) truck! It's a 2003 GMC sierra 2500HD. It has 250,000 on it and it runs and drives strong. Truck is a 6.0 crew cab, long bed. It's an SLE trim and has push button 4x4. It is filthy and kinda beat up but she runs and... the price was right. $750! The biggest issue it's having is the transfer case is catching and grinding from time to time. I think I'll just swap in a case from a wrecked truck to solve that problem. I also ran the VIN and it says it has a 4.1 geared rear with a g80 posi. I didn't think you could get a posi in an HD. So is it a posi or is it a full locker? Also it has a block heater and tge vin revealee it has the manditory canadian base equipment. Does that mean the truck was originally in canada? Tell me what you think and I'm open to suggestions on things to fix or inspect etc! Very excited to start wrenching.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
