short fuse ?
Hi folks,
I ordered a 2015 but haven't received it yet but wanted to ask.
The fuses for our 2014/2015 trucks - are they short fuses or the regular size fuses? Can someone look?
I want to order some "adapt" a fuses for a Dash Cam and want to know the size.
Greatly appreciated
TwoPlusTwo
The fuses are a new style for these trucks. Yet to see them elsewhere although I'm sure they are. Small fuse with long terminals. Known as "micro2" fuses. Also uses some triple terminal "micro3" fuses.
Micro2 P/N's 19209790 thru 19209796 depending on amperage. Also available on Amazon, Ebay etc.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
