What rear gear you running with a 4.8 2wd truck
I'm debating on swapping out my gears from 3.42 to factory 3.73 but with a posi.
I do have taller tires but maybe an inch taller.
The 4.8 needs more gear it seems when it's in od as its a turd.
Maybe with 3.42 gears and a taller tire its killing it
I've never owned a 4.8 truck, but I've owned and driven numerous 5.3 trucks with 3:42's, 3:73's, and 4:10's. IMO, going from 3:42 to 3:73 wouldn't be enough difference to justify the cost. If I was going to do a gear swap, I'd go with 4:10's. Then, you'll be able to hold 4th gear on the highway without any problems, while also having more grunt down low. My buddy had a 5.3 truck with factory 4:10's a few years ago. It drove really well, and got the same MPG as my 5.3 with 3:42's. We both had 285's and leveling kits.
Yeah I know it's not much difference but these are cheap with the posi.
I won't have to buy new gears but 8.5 gears aren't too much anyhow.
I mainly got it for the posi as I don't have one.
I can do the rear work myself also.
I may look into 4.10s since I have larger tires
I see. Yeah a 2wd truck with an open differential doesn't get around very good at all. It may not increase the performance much, but traction will be much better.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
