Does anyone know what fuse / location for power outlet on the back of the center console ( bench seat ) ???
One of the other “Retained Accessory Fuses” is labeled as #50 in the passenger side fuse panel.
But...  I just checked and when the diagram in the manual is lined up with the actual panel, there is nothing there. Love when that happens  ?
If anyone can shed light on that I’d appreciate it too.
Edited by TCSpeedy
My 2015 Sierra 2500 was just backwards.  I went from 11 to 10 to get the RAP to work on the dash cigarette lighter power supplies.  Is that possible?  It was in the 11 position and they stayed powered all the time.  I tried it the other way, works like a charm now.
LMAO to be 100% honest, when I posted the steps with pics, I made a mental note to go back and verify if I phrased it correctly because I had a suspicion I may have reversed the 10 to 11 or 11 to 10.
I never did get around to checking that but I was comfortable enough that with the detailed steps, even if I reversed it people would know where to go and how to switch whatever they found.
I think you just called me on it!!  Glad you ended up getting what you wanted out of it though!
Not a problem, I just thought I had one that was backward LoL  My luck kind of thing.  I did get what I needed with your help.  Thank you
On 7/14/2016 at 12:45 PM, sk said:
My 2015 does not have the wording in the manual either but if you look at the driver's side fuse diagram like I said in my post it will show you. The diagram says something like "#10 DC" and "#11 RAP" (I'm not sure that is the exact wording since I'm not at the truck right now but it's something close to that. Just look for the setting that says "RAP").
Perfect, glad to hear that.
I have the same question about my 2015 sierra.  Tge wording I the manual also states the RAP is always on and cannot be changed. When I look at the passenger side fuse box containing the RAP fuse block there are only 2 pins and no other position available to move it... anyone figure this out yet?
Earlier and later models all work the same as described in previous posts... move the fuse one position over.
Why would the 2015 alone be the exception.
AM I just not looking at all possible fuse locations?
Edited by Msstategrad
Typo
The one you move is on driver's side
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
