Owner's Manual is your friend...page 9-29, 9-30
Retained Accessory
Power (RAP)
The following vehicle accessories
can be used for up to 10 minutes
after the engine is turned off:
. Audio System
. Power Windows
. OnStar System (if equipped)
. Sunroof (if equipped)
These features work when the key
is in ON/RUN or ACC/
ACCESSORY. Once the key is
turned from ON/RUN to LOCK/OFF,
the windows and sunroof continue
to work up to 10 minutes or until any
door is opened. The radio continues
to work for up to 10 minutes or until
the driver door is opened.
Accessory Power Outlets (APOs)
The vehicle may have APOs in
several locations. See Power
Outlets on page 5-6.
The APOs in the console or center
seat position are powered by RAP.
They will continue to work for up to
10 minutes after the key is turned
from ON/RUN to LOCK/OFF, or until
The APOs on the center stack come
from the factory powered directly
from the vehicle battery, and supply
accessory power at all times,
regardless of ignition key position.
If electronic items are left plugged
into these APOs for long periods of
time with the vehicle off, the vehicle
battery could be drained. The
vehicle may not start if the battery is
allowed to drain for an extended
period of time.
The source of power for the APOs
on the center stack can be changed
from direct battery power to RAP by
moving the fuse at location 10, in
the left instrument panel fuse block,
to position 11. Once the fuse is
moved, the APOs will continues to
the driver door is opened. See
Instrument Panel Fuse Block (Left)
on page 10-49 or Instrument Panel
Fuse Block (Right) on page 10-52.
If you are not comfortable
performing this change, see
your dealer.
I don't swing that way, but I could just kiss you right now! I can't tell you how many times I had to jump start my truck because I forgot to unplug my dash cam. Overnight was usually okay, but more than that meant a dead battery. After it happened again yesterday, I was determined to find a way to make the power outlet go cold when the key was off. I actually came in the house to use Google to try to find a switched wire I could tap off of and run to a relay for the power outlet. I had Googled for solutions before but never came across this post. Like some of the others, my manual says nothing about switching the fuse to the other pins, but it worked perfectly. THANK YOU!!!
  • 1 year later...
I have a 2015 Silverado WT.  The fuse panel and the fuse diagram is really a little confusing to me.  Where the diagram appears to show two fuse slots, 10 and 11, the actual panel appears to have a single slot with three pins.  There is a 50 amp fuse located to the right as it came from dealer.  So if one assumes that 10 is on the left and 11 on the right according to diagram that seems fuse was in the 11 slot.  However, I am not timid, so I tried moving the 50 amp fuse from the center and right pins to the left and center pins and that did the trick.  Not sure exactly how but it did.  Also, my owners manual does not match the excerpt given on this site.
My 2018 owners manual says
"The power outlets on the center
stack and in front of the cupholders
are powered at all times. The power
outlets inside the storage area and
on the rear of the console are
powered when the ignition is on or
in ACC/ACCESSORY, or when
Retained Accessory Power (RAP) is
active."
Edited by Krom
My 2015 says same thing.  But moving one of the large fuses to the left changed the one on center stack to RAP.
Just an update, even though the manual says what it does, moving the fuse works on my 2018
Broke the top off the fuse when I moved it, problem is I can't find a replacement.  The Dealer only shows a 40 amp but it's a 50 amp.  I've searched the several different parts stores online and can't find one.  Any suggestions??
Thanks
Had to make a couple of stops, but found a 50amp replacement at advance
Edited by brholtz02
addition
Good.  I was going to suggest try the 40.  Worst that can happen is it blows.  I seriously doubt that the circuit draws 50 amps.  Good to know Advance has them.  Thanks!
Love the post, solves half of the problem that I was looking to solve as well, the APO that I wanted to be RAP was constant and I’ll try switching the fuse tomorrow (too cold out and I’m always afraid of snapping the cover).
Problem two though...  I have a flashing rear-window mounted warning LED bar that I’d like to keep flashing when the power is off and key out, so that I can lock my doors but still have the warning light active and visible.
That means I’d like to have the rear seat APO active at all times and NOT RAP.
Since there doesn’t (yet) seem to be a fuse swap for this, I’m considering using one of the “spare” slots and installing a mini USB hardwire kit like this:  (which would also work for a dash cam/GPS if you wan to keep your outlets open, or for a cleaner install)
Edited by TCSpeedy
Spelling
I have not looked for that but I did notice several of these fuses with female contacts so guess it is possible it can be done.
Finally got around to switching the fuse from one side to the other (position 11 to position 10) and it works perfectly, as hoped and expected.
As far as the “six pins” questions some have had, yes this makes perfect sense and is exactly what I would have expected to find.
Imagine that the center two pins allow power to travel TO the outlet...  so now there needs to be a power supply to get that power there.  It either comes from one pair of pins that is constant from the battery, or the other set of pins that is RAP, or interrupted when the key is off.
Switching the fuse from one position to the other accomplishes that goal.
It makes the whole process a lot easier by being able to come here and easily find the fuse location, and a clearer understanding of which fuse is which rather than trying to interpret the manual, but that’s just my laziness talking!
Now I’ll continue the hunt to see if the other (back seat) outlets can be altered in the reverse way, from RAP to constant.
But I only saw three pins is the reason I questioned 6.  Maybe these old eyes do not have the resolution required to see 6 that close together. #1 pin to accessory control circuit, middle or #2 pin to outlet and #3 pin to battery.  Don't see need for 6 pins.
To be honest, I didn’t bend down to the angle needed to see if there were only 3, or 6 pins in there. It’s -16° here today, and dirty...
But 6 would allow for in/out completion of each of 3 circuits, and while I’m no DC expert, logic dictates that’s a likely scenario.
I’m just happy it worked. I went through the manual again and sadly I don’t see the same simplicity for reversing the rear APO’s.
You’re right. 3 pins. The panel is grounded so the hot is the only circuit required to run through the fuse.
Thought I’d include a better write up and broader picture of what you’re looking for.
In the driver’s side fuse panel, pink 50a fuse is now in position for RAP for the outlet on the dash. It was originally in the other position from the factory, for constant power...  just pull it out and move it over.
Also, for what it’s worth, it’s much simpler to slide the fuse puller on from the side rather than force it over the top.
So glad I found this thread, it accomplished what I was looking for.
Edited by TCSpeedy
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
