What noise is this ?
Yall got any idea as to what is causing this noise ?
I was thinking front universal joint or maybe CV axle ?
Truck has a 6 inch lift and 37s. Only 3k miles on lift and tires ? Premature wear maybe ?
I believe its a the universal joint on the front driveshaft. The one going into the transfer case. I jacked up the rear end, put truck in neutral and rotated the drive shaft and i could hear it squealing and whining. It kind of pops when driving
It does haha. Isn't that how it can have full time 4wd? Front d/s keeps spinning but the hubs just aren't locked ?
Anyone have any insight on replacing u joints on front driveshaft? Easily do-able?
CV's spin in 2wd and hubs are unlocked. They lock in 4wd and auto. I'm hoping your lift had a differential drop. If not then your u joints are longggg gone at that type of angle.
Yup it has a diff drop. I believe it's just time for new u joints haha. Stuff is gonna break on a truck with 234k miles
What makes you think it's the xfer case?
It seems to be coming from that general area. I'm just gonna take it to my mechanic i reckon. Goodbye paycheck ;(
Usually CV joins click when turning. Is that noise only happening under power?
Yessir, only under power. When you put it in neutral and are still moving, the noise stops.
I had the rear jacked up and the front driveshaft out, and the noise was still persistent. This rules out CV's, no?
