Red loctite on inner tie rods?
Hey guys... I've been reading into the tie rods on these trucks and a lot of sources say to use red loctite on the new inner tie rod. Do the old ones have red loctite on them? I hear it's impossible to remove without heat... which I don't have. Is that true?
I think so , they come off WITH OUT HEAT , use a big wrench and pull , if the threads have a light coloured substance , then yes , use loctite ,
It won't damage the steering gear?
There are flats on the rack I think that a wrench can go on ,
I thought you had normal steering linkage lol
Red 262 Loctite for installing the new ones per the GM R&R instructions, torque spec is 111 ft.lbs.
I believe that is correct, having done mine last summer.
Crows foot wrench (36mm ?) and big breaker bar eases removal, although I've heard success with big pipe wrench. I did not have to apply heat.
Get a pair of narrow screw / worm clamps to replace crimped-on clamps around boots (5/16" x 2-1/2").
When ready for install, I sprayed out oily female receiving end with brake cleaner & dried. Thread lock came with Moog replacements.
On my current truck I didn't have to use heat, but just a big freagin' adjustable wrench. Once they popped loose it was easy from there. They didn't look like any kind of locktite on them. Of course they may have been changed before, after all with 300+k miles anything is possible. New one went pretty smooth, good and tight and I called it good. I don't think Loctite would hurt anything if you added some.
Did you have to hold the steering linkage at all? I got the inner tie rod tool so I have basically the socket I need and a breaker bar, I just don't want to hurt the steering gear or I'll be in a world of trouble.
No. Just don't beat on it with the BFH & you shouldn't damage steering gear.
Don't forget the narrow screw clamps for the boots.
Edit: Service Manual DOES call for a pipe wrench (?) to support inner tie rod rack end when loosening.
I've not heard of anyone needing such, nor have I seen anyone using one on the numerous Youtube videos.
I was reluctant to gouge up rack, so I eschewed that suggestion.
Note also, the exist'g inner tie rod "flats" (for the wrench removal) may be obscured by a plastic sleeve (called a vibration dampener (?)) will have to be slid out of the way to gain access. Took me a couple minutes to figure that out.
Okay cool thank you, it sounds like everyone I've talked to don't secure the steering gear but the more people that say it the better I feel lol
PS: "Narrow" hose clamps I found were mfr Breeze part no. 3632.
thank you! Where did you get them?
also, what did you do for the thin end? what size were those?
If you're referring to small diam. side, they are reusable spring clamp type.
I got the larger narrow ones from McMaster Carr part # 5388K34 $10 sold in boxes of 10. Fit perfectly.
I see you're not far away. PM me if you like. I can part with a couple.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
