07-13 Silverados/Sierra Feel Cheap?
The dash cracking must just be a southern truck issue, pretty uncommon up here. Mind you, our two hottest months are July and August.
I'm sure its heat related. I noticed the other day that now the dash piece closest to the windshield is cracked. (Not the main dash piece that was warrantied) my buddies 2012 sierra Denali cracked as well. Same spot our Tahoe did the first time.
  • Replies 34
Not a southern truck issue at all...more like crappy GM engineering. There is a facebook page for GM Cracked Dashes and there are trucks and SUVs from all over the country, north to south, east to west, and everywhere in between. In fact, several of the latest postings on the page were from Ohio, Maryland, northern California, and Washington. The dash in my 2010 Sierra cracked in the winter time. GM has flip-flopped back and forth, blaming it on everything from cleaning agents used on the dash to heat, but yet, they have since updated the dash panels and added more structural support in the areas prone to cracking. Why would they add more support if it wasn't an engineering failure in the first place?
  • 1 month later...
I had a '00 Silverado LT with leather buckets. The leather split on the driver's seat at 35,000 miles (I'm a big guy, 6'4" 255 lbs). Dealer replaced the leather for free; I didn't even buy the truck from them but they were really good about it. 30,000 miles later, it split again but no warranty 2nd time. The interior, in general, was pretty well made though kind of plasticky.
My '13 Sierra SLE interior seems a bit cheap. The dash materials are thin and a bit flimsy, the cloth seats already show some wear at 6,000 miles. (I bought the truck brand new. My first brand new truck ever.)
But I am very happy with my '13. Like others mentioned, it drives and rides way better than my '00 and has way nicer features than my '00. I have no squeaks/rattles and everything seems to fit together the way it should.
The worst problem I had with my '00 Silverado is the rocker panels rusted out way too quickly. I had my '13 rust-proofed and had spray-in bedliner sprayed on the rockers and bottom edges of the body when it was brand new to help with rust and stone chips.
Go buy a Dodge and you'll thank god you have a GM product. I traded my 09 Ram for a 2013 GMC Sierra and couldn't believe the quality difference. 09 Dodge,Doors rattled,if you touched the body with anything the metal dented and just felt much cheaper.Rear limited slip went out twice in 60k. GMC feels like twice the truck.No rattles,quality feels much better.
I had a 2007 Sierra SLE RCSB 2wd w/5.3afm that I bought new but leftover in late 2008. That was a very solid truck for a first year body style. No major problems in 150,000+ miles, just the normal rotors once, rear drums and shoes once, and the door latch assembly once. Not one engine or transmission or suspension issue. It had a cloth interior with a very durable material, kind of a very soft suede?
That got traded in late 2012 for a 2013 Sierra extended cab SLE 4X4 w/5.3afm. Its got 70,000 on it now and not an issue yet. Very solid, quiet riding truck. The only thing I have done is front brake pads @ 50,000 miles.The interior quality is a bit suspect, I dont think the cloth seat material will hold up like the 2007.
    • I have ordered the car link adapter and registered for the google dev, will need to finish verification process later this evening when I get ahold of our kiddos android tablet. I will be using windows vs mac so hopefully it goes smoothly. I have zero tech background but I feel I can manage this with your write up.    Do you think it will be different for me? My truck is a 2023 GMC 1500, I have looked heavily into the AI boxes but I consistently find common complaints with lag.    Does carplay auto open now that you have it set up when you get in truck and turn it on? Or do you have to do open the app everytime?
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
