1500 with 6.2 or 2500 with stock engine
2014 LTZ 4X4 double cab with a 6.2, 3.42 rear axle, Firestone airbags, and Bilstein 5100s at max lift. I ended up with a truck that gets between 19.5 and 20 mpg running up and down I-5 empty and 16.5 towing the race car on an aluminum trailer (total 4,000 lb). The truck sets pretty well level and high enough to look like a real truck. When I tow either south or east over the mountains it maintains 65 mph in cruise without any effort at all even over the mountain passes. I came from a one ton diesel and this is the best move I've ever made. Wooo Hooo!
I have a 2009 RC 2500hd 4x4 6.0L with 4.10 gears, it pulls great, gas milage is around 14 empty and 11 with a good pull. Also I have a 2014 CC All Terrain with 6.2L with 3.42 gears it pulls really good but can"t handle the weight like the 3/4 ton can. I didn't want to put airbags on my half-ton since I have them on my HD and use them all the time. When I pull something I use the HD, when I want to drive somewhere I use the All-terrain.
Owning both, under the same conditions that you get 14mpg with the 6.0 what does your 6.2 get?
It does get 14 mpg, its not that hard to get that either, efi live tune helped a bunch. My 6.2L gets between 16 and 18 mpg, 16 with winter fuel and 18 with summer blend, it is also efi live tuned.
seriously doubt a 2500 with 6.0 will get 14mpg
I had an 02 2500hd 6.0 that would get 13-14 hwy with the old 4spd if I kept it under 65. Reg cab long box 4x4, 4.10.
I got rid of it because of the piston slap,?I guess they must have solved that issue a long time ago.
I have a 04 Denali 1500 with the 6.0, blackbear tune and I baby it it barely gets 14mpg almost all hwy commuting to work. Throw in some city you are 12-13mpg easy. One thing I have noticed is if I fill up then go right to the hwy it will stay at 15mpg a lot longer so the computer is probably lying. 300-330 miles per tank and probably 22-26 gallons used is right around 12-14mpg. GM/EPA were lying their arse off when the gave the old 6.0 14city 17hwy even on the 1500s, maybe flat ground with a rear wind going 47mph
I sure hope the new 6.2 gets better mileage, that is why I ordered a new denali. No way an old 6.0 2500 gets 14mpg, the newer ones maybe
    HWN808
    HWN808
  • Who's Online   2 Members, 0 Anonymous, 668 Guests (See full list)
