What HID kit for Silverado? Advice/input needed
Not very pleased with the light output on my 2014 Silverado. I want to convert to HID lights but after doing some research looks like need capacitors and resistors. I've seen some kits that say the capacitor is not needed or that it's "built in".
For those of you that have converted from the stock bulbs to HID's can you please chime in with your input and advice? What kit(s) would you recommend?
I searched for threads but didn't find anything too helpful, if theres a thread for this topic paste the link!
Thanks in advanced.
Jerry.
  • Replies 31
I had them on my 2004 Silverado. I did not care for them, On coming traffic was flashing high beams all the time. The HID bulbs did not last very long, brnt out. Went back to stock lighting.
Check out the K2XX 1500 forum, lots of info there on HID conversions.
Check out www.fastheadlights.com. They can do a complete retrofit for you. They did my lights, I had them add color changing halos. It's cheaper without it though.
i got some morimoto hids and love them. soooo much nicer and brighter than stock bulbs. also, make sure you aim your lights, especially if lifted or leveled. no one flashes me at all.
  • 2 months later...
Jarom, I own the same truck as you (Denali HD 2015 black on black witht he D-Max engine) and I am trying to figure out where to find the ''changing halos'' on the fastheadlights.com website. Do I need something else than this kit if I want the ''changing halos'' ?: http://www.fastheadlights.com/ProductDetails.asp?ProductCode=fxr%5Fretrofit%2Dkit
Also, when referring to ''changing halos'' does this means that you can select the color of the halos yourself of they just change by themselves while they ''heat''?
I'm also confused about which type of DIode Dynamics LEDs for my fog lamps...
Thanks for the help
David
  • 3 months later...
I just bought a complete HID kit from www.theretrosource.com I am installing it today however I couldn't be happier with the customer service as well as the quality of the kit itself. If you have any questions those guys know their stuff and they're fantastic to deal with.
  • 3 weeks later...
I just ordered a set from VLEDS. They have the LMZ kits down to $130, and offering 20% off since they are out of stock until the 16th.
http://www.vleds.com/shop-bulb-numbers/h-series/h11/h11-ultra-lmz.html
I currently have VLEDS HID kit, and now have a bulb not lighting up. With work being crazy, I haven't even had a chance to figure out what went bad yet. Checked all my connections, and see nothing wrong. I'm hoping tonight to swap the ballasts from one side to the other to see if it is a ballast, or bulb.
That is a totally different scenario. The 2015 HD has projectors which are really work best with HID's.
I recommend the Retro source. Not cheap but good service.
The Silverado has 4 bulbs - keep the high beams xenons like Silvertstars. I DO NOT recommend LED's. They aren't the best- HID is the way to go for brightness. I have xenons in(not HID) and they are a marginal improvement.
I have to say, my LED High beam and Fogs are brighter and provide more useable light then my HID headlights. It's been bugging me so much that I have LED for the Low beams on order. Then, all 3 will be same type, and "model" with the only exception being H11,9005 etc..
I've been researching this for a few weeks and trolling this and other forums and the consensus seems to be the Morimoto Sierra spec, if you want to spend the $$$.
Morimoto Sierra Spec: Morimoto Elite HID System - 5500k KIT The Retrofit Source $156.24 $156.24 $156.24 This is the one that Retrofit source recommends
Buy URL: http://www.amazon.com/Morimoto-Elite-HID-System/dp/B013N20NSU/ref=sr_1_1_m?s=automotive&ie=UTF8&qid=1442849575&sr=1-1&keywords=9012+Morimoto
Spec URL: http://www.morimotohid.com/hid-systems/morimoto-elite-hid-system-sierra-low-beam.html
Morimoto Sierra Spec: Morimoto Elite HID System - 5500k KIT The Retrofit Source $170.00 $170.00 $170.00 This is the one that Retrofit source recommends
Buy URL: http://www.theretrofitsource.com/hid-systems/morimoto-elite-hid-system-sierra-low-beam.html#.Vf1s05WFNaQ
Re. the fogs:
Morimoto GM XB LED Fogs 50374 $170.00 $170.00 Y $183.94 This is what Morimoto recommends
Buy URL: http://www.amazon.com/Morimoto-Type-LED-Projector-Light/dp/B00XA3C0FC/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1442852322&sr=1-2-fkmr1&keywords=Morimoto+50374
Spec URL: http://www.morimotohid.com/complete-headlight-fog-light-housings/morimoto-xb-led-fog-lights-type-gm-h16.html
Re. the projector housings, sounds like it's a lot of work (and cutting) for very little ROI.
Oh, for 2015 you need the 9012 headlights (one HID does both low/high beams) and if you're lifted, as others have said, re-aim.
I have LED's for lows, would you guy's say that HID's would be better light output ? 2015 Chevy Z71 with projector lamps. looking for the best . Any information will be helpful.
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
