Rear Diff?
I heard a small pop this morning and then some slight popping then later, a larger one followed by the motor shutting off. Coasted into a parking lot. Can't move, if you put it in gear, it goes nowhere. Is this is the diff? I have the 10 bolt, g80 with 3:73s
Possible pinion gear or the G80 locked up and exploded. Where you making a turn when you did it? Quick tell is to remove the cover and see.
It was going straight and locked up enough to kill the motor. had to put it back in neutral and start it to coast
I guess the real question is, what are my options if the diff blew up?
This is all speculation I'm afraid and a mere conversation ,,,,,, no one is going to entertain premature questions as it can be a million things .... Come on ...
In my opinion if it was the rear end you wouldn't be able to move even in neutral.
Yep, if the rear diff locked up you wouldn't be going anywhere.
How many miles on your truck and how does the transmission fluid look?
Tranny has been rebuilt. It was the diff! having it taken to aamco tomorrow for a rebuild. Put it in gear and the driveshaft started spinning until a piece of the gear pierced the cover.
I coasted in neutral from when it broke to a parking lot. After that it wouldnt move, even in 4wd
Sure you can't find a decent place to take it?
They rebuilt my tranny last year. No problems out of it.
They wanted the same as anyone else. Spider gears, ring and pinion, carrier, locker, bearings, and two new axles.
