TSB on 6.2L
On Monday, I was suppose to take delivery of a new 1500 SLT with a 6.2L and off-road package. Dealership told me they could not release it yet as a "global" TSB was issued on all 6.2L due to a "whining" in the transmission. All week I have been waiting but am being told that the "GM portal does not show any fix yet." Anyone heard of this or have any helpful info?
Its just one of those things that if you run into that whine noise, that they are aware. If it makes no noise, then I wouldn't worry.
Has to be something more than that. The dealership will not let the sale close and they tell me they cannot release the truck until a fix comes through. They have guaranteed the price and rebates as of 3/30 but the sale is otherwise in limbo.
Got a link to the truck on the dealers website?
Will the "fix" be a pair of earplugs?
I just turn up the radio. Mine whines a little mid-gears +/- 30mph,.
It takes a while to write up a new TSB stating "Normal Operation." On second thought, they should have plenty of those around, they'd just need to change the title.
Sounds like they are taking about preliminary TSB 15178 for 8speeds whining in 3rd through 5th, and yes, the bulletin says they can't sell a truck that shows symptoms of it. It affects ~5% of 8speed transmissions. My understanding is it is for "earlier" builds, and they even know the VINs affected. Has the dealership confirmed yours is affected or are they assuming? Easy enough to find out on a test drive, or calling TAC to verify the VIN.
Edit: I am lead to believe the parts require a transmission teardown as well. An alternative is to ask them to swap the tranny with a new unit. Or, look for a truck that doesn't have the issue if you don't want repairs right off the bat.
Can't thank you enough for the info. I asked the dealership those exact questions and they admitted to what you said. Said originally the TSB didn't have a no sale mandate - huh? They were going to sell me a $50k truck they knew to have a known problem simply because the TSB didn't say no sale? Starting off a new truck with a transmission rebuild is no bueno in my book. Walked from sale and now looking for another 6.2L that can be shown not to have same problem.
Glad to help. Totally with you on not liking a new vehicle needing a tranny rebuild right away. But hey, I already had a new replacement 8 speed transmission put in my Denali in less than 2 months of ownership *sigh*.
To clarify a point I said earlier, they can technically sell the vehicle, but they should not let a customer take off with it until its fixed, which still isn't very cool in my book. The exact wording from the document is:
"If gear whine noise is present, the vehicle should be held and not delivered to a customer until the bulletin is released and repairs can be performed."
When you go looking for another truck, my understanding is ones built within the last month or two are not on the list. The 8speeds transmissions don't sit very long anywhere before they make their way to a vehicle. Foolproof check is the dealer can pull the TSB and look at the list of vehicles to see if it appears on the list as possibly being affected.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
