Zone 2" level
Anyone else use this kit? Had it installed with nothing in the back and it seems the back rides a 1/2" low. What size are factory blocks in the back? Thanks in advance
I have the Rough Country 2" front lift. I seems to sit low in the back now also. I thought it would just lift the front enough, since they offer a 2 1/2" front/1" rear kit. I just wanted to get the attached snow plow look gone. I think the stock rear blocks are 1". I am taking it to a place that has various size blocks and see what I need.
Yeah it does suck, but in my opinion still better than stock look. Hey let us know what size blocks you end up going with, please. I seriously think the 2wd is the same height as the 4wd is in the front, GM has always done this. Atleast we don't have to mess with the torsion bars to get it level anymore.
Well, what I did was call Rough Country today and was able to order just the rear blocks and u bolts for $57 shipped. I haven't measured the stock rear blocks, but according to RC they are about 1 1/4" tall, and the the RC rear blocks are 2". Hopefully that will look good. I'll try and get some before and after pics.
I'm using a Zone 2" inch and I think I'm pretty damn level. 6e4dbf031ccddada6a46d24acf1ea0dc.jpg
Actually, that would be a lot easier. With those you only had to turn a bolt a few turns. Now you have to install something. The torsion bars are infinitely adjustable and a lot easier to use.
I was actually referring to swapping out keys. Not just turning the bars. And this time it was considerably easier as I just paid someone to do it.
I know mine is an older generation, but the suspension is the same. I've got the Zone 2" front & rear kit. Had one on my 2009 too. It's the 2" spacer for the front, and a 2" block for the rear. On my 2009, I stacked the 2" Zone block on top of the factory 1.25" block. On my current truck, I just replaced the factory block with the Zone 2" block. I've got about 1" of rake now.
I have a Zone 2" Level Kit on mine and the front is 1/4" lower than the back with the Bilstein 5100 Adjustable Shock on the stock setting.
No pics tonight,k but I installed the rear rough country rear blocks from the 2.5" level kit. To me it looks great. It has just enough rake with the 2" lift up front. I'll try and get some pics tomorrow. With the RC block next to the stock block there is just less than an inch of difference, but when on the truck it appears every bit of an inch taller in the back. It sits perfect for just about $120 plus an alignment.
While you 2500 High country is sharp it has nothing to do with a leveling kit for a half ton.
  • 4 weeks later...
If the Zone spacers are too much, can they be milled down a bit?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
