Here's my System
Nice!  :thumb:
You running 8awg for each amp? Is that enough? I went ahead and ran 2 8awg to my big amp. It was cutting out with only one going to it. I figure with those 12's pulling from it, and no Cap (I didn't see one anyway), you would have the same problem.
Check out this thread for mine.
Well im running 4G, it splits off into 8G  because its a short distance and their's no power loss. I don't really experence any power loss with out a cap, but it barly dims my head lights. If i was going to go with something like a  cap i would probably just get another battery very worth it. My truck really doesn't take that big of a hit with out a cap so i just left it the way it is. You can get away with using 8G only if its a short distance. My 4 channel is 450W amp and my Alpine is 1500W Peak for my subs.
:jester:
  • 3 weeks later...
Wow, your system is alot like mine, I like how you kept the amps under your rear seat. Looks very clean. I wanted to do that but I have a 2 door, and the back seat was not wide enuff. But i got a question for you. My setup up is like this. I have a Mtx-6500d for the sub and Alpine MRV-T757 for the components. I have white wolf RF Rca running back from the head to the alpine. Then from the alpine outputs i have monster rca like yours running to the MTX. I notice the bass does not sound as full. So i switched the Rca's, running into the mtx then out to the alpine, and i got the same effect on the components. Do the out puts on these amps not support such high wattage?? do you run into any problems like this???
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
