gm rivet kit???
so i was installing my new oem splash guards tonight and once i did the rear set, i moved to the front.
the directions called for a "rivet tool" it looks like it spreads the special nuts supplied in the fender.
does anyone know where to buy this>?
how much
this seems like something that is cutom to GM
it had a specific bolt washer and "ANVIL" looks like a nut
i understand how it works.....
im wondering where to get one since the splash guards i ordered did not come with the kit
You don't always need the special rivnut tool to install rivet nuts, that is if it is a rivet nut they are using??? Basically a rivnut tool has a draw stud with the same thread as the nut that will seat the rivnut into the sheet metal. If you don't have the tool you can use a screw and a regular nut with the same thread as the rivnut and use a few washers as a thrust bearing.
Place the rivnut into the sheet metal. Get the screw and thread the regular nut onto it than put on the washers. Screw this into the rivnut and turn the regular nut while holding the screw from turning to seat the rivnut.
Hope this helps
Another variation of the rivnut is the plusnut which just has 4 slots in the shank and allows the backside to expand into 4 petals with less force than a standard rivnut. The plusnut is the recommended type for plastic or thin sheetmetal.
Harbor freight sells a kit . I bought one to fix some I ripped out on my rt challenger
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
