Installed 2014 sierra auto release tailgate
I gotta figure out how to wire it to a switch in the cab and use the factory fob and this would be awesome!
Get a 2 pin momentary switch, ground one pin and send the other pin to the relay pack.
Look up PAC tr7. You can program this module to 5x unlock presses to release the tailgate actuators
Im trying to find a decent spot in the truck to mount a switch. When i do, i will post more pictures
That Pac module seems like it'd be the ticket but that is some confusing mumbo jumbo on how to wire it!
  • 1 month later...
  • 1 year later...
