HOWDEE from So NV newbie
Brand new member of gm-trucks. Just picked up my '15 HC 6.2 8-sp with HC premium and hole in the roof deep ruby metallic yesterday.
Traded my '12 with 6.2 and looking forward to better mileage. '12 had 3.73 gears and the'15 has 3.23's. Look forward to
sharing the vast amount of info I've surfed so far. Hope GM listens to all the members.
What are your comparisons 2015 vs 2012? I have a 2010 so I am curious on your thoughts
Ryan
Hey Ryan,
Good question about the '12 and the'15 6.2 comparison...Just got it and only 65 miles locally.
Best able to give an honest report card after a couple months. Mechanically am interested in the
difference between the 3.73 old to 3.23 new gears and of course the new 8-speed versus the 6-speed.
Also hopeing the unloaded mileage goes up about 2mpg due to the 15% reduction in rpm. Old '12 was
2000 rpm at 70 mph and new '15 should be 1700 rpm at 70mph. If you as an admin spot a valid comparison
in the forum I'd appreciate sending it along. Thanks, Jim
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
