Time for tires...advice help
PMWZ71
Time for new tires as stated. I have a 2012 Silverado with a RC 2"level. I currently have 275/65r18 terra grapplers with stock wheels but want to go bigger. I found out that a 275/7r18 is a good bit cheaper then the 285/65. Will it fit with the 2" level without rubbing? oh and I have front splash guards to protect from rock chips on bottom of doors. I was told it would but want some input from others on here.. Thanks for the help.
Fit fine with a level
Ryan
Never had a rub issue
Ryan
And it looks like you have the same front mud flaps as well. Good to know. Thanks for the help. Going with the new bfg ko2.
I will be going with those next
Mine are the stock chevy mud flaps
Ryan
Yep, the 275/70/18's should fit just fine with a 2" level on stock rims. That's a pretty common setup, and looks really good.
