BIGRED811 Posted June 7, 2019 Posted June 7, 2019 King 2.5/3.0 and Fox reservoir coilovers both have to be adjusted off of the vehicle
Rock1500 Posted June 8, 2019 Posted June 8, 2019 I had mine lowered 1.5” which is what Bds recommends to still run 35” tires without rubbing I don’t remember the fender measurements. First pic was at 6” lift second pic is lowered to 4.5” lift. If you do lower the front make sure you switch out the sway bar drop bracket to the one used for 4 in lift kit You can lower your 6 inch lift to 4.5? **** and I bought a 4 inch lift!!!!Sent from my Pixel 2 XL using Tapatalk
