Rotor rust
Ok, its a 2012 and the rust is starting to overtake the wear surface....really? Its only affecting the inboard shoe/surface, but it has less than 55k on the clock.
I found it because I started hearing a rubbing sound from the driver's side, the scale is causing it. Its not the first time I had this, but that car had well over 100k miles on it. Its only crept in about 1/4", but once it starts; there is no stopping it. I peeled most of it off with a bastard file (spin the rotor and use the file like a scraper).
So I figure it will need new rotors next summer. What is everyone doing to prevent the rust? I'm thinking of degreasing the new rotors and painting everything but the wear surface and mounting surfaces with high temperature paint. Thoughts?
Did the truck sit for a few days? Rotors will get rust spots on a brand new car while sitting at the car dealership and all you have to do is drag the brake while moving to get the rust off.
No, this is heavy scale that creeps in from the edges....the brake pads won't touch it. The pads actually start to wear to the rust after a while.
Sent from my SAMSUNG-SM-G730A using Tapatalk
My brother in-law just switched his 2012 over to the rotors used on the 2014 and up.
This after seeing mine go through its first salt infested winter and mine still look great.
The new rotors GM put on the trucks hold up very well.
They are just off color on the outside edge and no real sighns of rust.
They also never get the rust spots after a rain storm.
So if your looking for an upgrade this is what I would suggest.
