LockPick for the IntelliLink?
Has anyone heard if LockPick is developing a module for the IntelliLink system? I installed one in my dad's Ram 2500 and it's very useful.
Nope. They are not developing one as far as I know. LockPick has been slipping here lately. They haven't rolled out any new stuff in a while.
I got this unit and I have been happy with it. I have a 32 Gig USB stick in the console with a stack of movies for myself and the kids. Works great once you figure out the right resolution and bitrate on how to render your videos to.
http://gm-navigation.com/gm/gmc-navs/2013-2015-gm-video-in-motion-and-navigation-unlock.html
They also have a module that allows you to mirror your phone on the head-unit as well.
I was going to suggest MVI as well. I had a lockpick on my wife's Grand Caravan for one reason mainly- so that she could set a navigation address when I was driving. GM has thankfully done something reasonably intelligent and even though they pop up a warning, they allow you to tell it "I'm the passenger" and let you proceed.
i thought this was the case as well but it seems that the car is detecting the passenger to offer this..unless its a setting somewhere im missing
Passenger presence system. Primary purpose is to gage the size of the occupant. But like so many other sensors today the data can be used for many other purposes.
Seat sensor. Same one as the seatbelt warning sensor.
That has got to be the most logical use of that sensor I have ever found. :)
The lockpick was also nice when we would have to adjust movies when the kids were little. Now that they're 12 and 13 they don't really speak to us any longer and stare at their phones.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
