Rear lift block kits
Looking for a 2" rear block
Front leveling kits are $65-80 but vendors want $150-200 for a kit with rear blocks! What's the right kit out there, I see a bunch of cheap ones but aren't sure what people are using.
The Rough Country kit that has a 2" rear block comes with the bigger U- bolts to fit the bigger block and also comes with 1/2" spacer that goes on top of the front shocks.
It's the rough country 2.5" level kit.
Or you can contact rough country and they will sell you the 2" block all by itself
I personally have the RC 2.5" level kit with the rear block installed. Love the look
My plan is to use bilstein 5100 leveling shocks at the highest setting, but I want to retain a slight rake so will also swap out the factory rear block for a 2" (or 3"?) - I am not sold on the block style leveling kits in the front, seems cheap to me and many people I know who have installed them (GM trucks and other makes) report having tire wear issues and ball joint issues. Since the rancho shocks that came on the truck from the factory kinda stink anyhow, and my truck now has 36,000 miles, I figure swapping the shocks out will be needed by 50k anyhow so may as well do it @ same time.
Right - I just want the rear block kit so I can save an easy $40 or so
