BODY LIFT
if i go with the zone 1.5 lift. wil the tow hooks have to be removed like my 2004 with a 3in had to ? thanks in advance
Will be putting this kit on soon, from everything I have seen you just have to flip them over maybe someone that has installed already could let us know for sure
There is a Utube video that will answer this question. If you search zone body lift and then watch the one by Fastheadlights. If you don't want to watch it then the answer is yes you will be flipping them over and re-use.
trying to install this kit right now on my 2014 sierra double cab 6 ft box and the kit # C9151 doesnt seem to have enough blocks for the box?? has anyone put this kit on the same truck set up
I have the zone 1.5 on my 14. Tow hooks are not removed.
Don't know sorry.. drives fine little more bouncy and little power loss but expected.. don't tow much sorry no help there either
Would you or anyone know on the bed lift I took out 4 bolts per side but have only 3 spacers per side to put back in am I missing something here front went good thanks
Did you figure out the blocks for the bed need some help here also
