I am also having this same problem on my 2015 SIERRA. Gmc customer care is useless. They have ghosted me on two seperate occasions now I will not even bother contacting them on this issue. The volume goes all the way up on its own. I've tried everything. Truck was bought new by me, it has 120k miles now. I've replaced the transmission once at my cost because gm said it was fine...... had lifters replaced for the afm after leaving me stranded and losing 4 cylinders, a/c condenser replaced (bad welds), driver seat covers replaced twice for tearing (I'm only 200lbs), had to the dealer twice now for being stuck in 4 wheel drive to have computer reflashed, the rear right leaf spring came apart about 20k miles, the transfer case has so much play in it, clunks going in and out of gear. When doing my very first brake job at only 20k miles it was realized the calipers were installed in factory with absolutely NO GREASE on the caliper pins,  causing the premature wear. My mother has a Denali with the same radio as my sierra and it has already been replaced by dealer for around $2k. Been a gm guy my whole life and been happy with that decision but these new trucks are garbage. And gm customer care doest care at all...time to make a change. I'll bet the steering wheel controls are the issue here, probably in the steering column. Yay
Not sure if anyone has the same problem as mine, but I fixed mine on 2018 gmc sierra
My volume could go up to 30 ish in volume, when I put it louder it would go down in volume. Has done this to me twice in the last few years.
The way I’ve solved this problem is connect my Iphone to the stereo, open Apple car play, goto maps, pick a destination, when she talks turn up the volume, then it fixes your music volume. Not sure why they intertwine with each other sometimes, when they are supposed to be separate.
hope this helps someone.
Edited by FlipzZz
Insert truck info
2016 GMC Denali dualie-same problem with radio.  All of a sudden volume goes up & then down.   Red line shows how far volume is up & then a smaller red line continues from that red line.  Just turned truck off & turned auto volume off.  Volume works now.  So we will see as I have tried everything else!  Just found this website so thanks for advice!
First time this has happened to me.  Had the truck for a year and a half.  Was in it all morning, everything normal.  Got back in it after lunch, radio full volume with no control, no response on the screen.  Turn the knob really fast would get it down, but would return to full volume on its on. Shut the truck off several times, no change. I recently replaced the starter, matter of fact, the day before this incident. The radio has done some other funkie things on its own, but not this.  I thought the speakers were gonna blow.  Any suggestions??
  • 5 weeks later...
I know this is an old post but I just had the same problem where my volume would immediately start going down to 0 every time I tried to turn it up. After frustratingly trying multiple things, here is what worked: once it hit 0, I spun the knob like I was turning it down, and then the next time I tried to turn it up, it worked and has been working since.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
